20k Garwood winch install on a Deuce
779
20
Springfield AR
Ok guys I picked up a NOS 20k Garwood winch I plan on installing on my bobber. Here's a video of the winch. I am going to be looking for the Level wind assembly for it as well. I am looking for the TM for this winch as I need to swap sides for the pto hookup from the passenger side to driver's side. Here's the threads I have found on this subject. http://www.steelsoldiers.com/showthread.php?15174-5-ton-winch-on-m35a2 http://www.steelsoldiers.com/showth...I-have-a-5-Ton-on-my-Deuce-need-to-right-size http://www.steelsoldiers.com/showthread.php?3760-Will-the-winch-from-813-5-ton-work-on-m35a2-Deuce http://www.steelsoldiers.com/showthread.php?103077-5-ton-winch-on-a-deuce. I found a pic as well. https://youtu.be/SEsU0CxwrRo
73m819
319
gainesville, ga.
Just remember that will be a LOT of weight on the front axle, a lot more then a deuce winch.
779
20
Springfield AR
Yes it will be trust me my back feels it today after pickup yesterday. I have 18 ply 1400-20 NATO NDTs. If I need to address anything as far as my leaf springs I'll look into that after the install. I will also be looking at anything I can do to reduce weight in other areas as well up front if need be. I have been reading a lot on this subject.
73m819
319
gainesville, ga.
It is not so much a spring issue but a axle itself loading issue, the front axle is very close to max loading with the deuce winch.
779
20
Springfield AR
Ok after some winch wrestling I finally have the winch apart. It had some water in it so have to change the worm gear bearings and lower seals. Does anyone have part numbers for those and can I get them at Napa?
rustystud
2,793
Woodinville, Washington
You can add a front axle "truss" . I've seen this done several times. I'm thinking of doing one this summer. Of course this "truss" will do nothing for the extra load on the wheel bearings.
dilligaf13
34
south, florida
I'm just curious why you went with this winch setup, especially on a bobber? I know the PTO winches are better than electric but I really think the warn 18K would have been better if you wanted more power than the standard deuce winch.
779
20
Springfield AR
I know but got a good deal on it only need to change the worm gear bearings and seals. I don't think Im going to use the stock rollers they weigh almost as much as the winch so a huge weight savings there. I just can't find those bearing and seal numbers in the TM I have.
779
20
Springfield AR
My son and I cleaned up all the winch parts yesterday. I ordered 2 worm gear seals and 2 bearings from Car Quest. I just have to assemble it and figure out mounting and if need be I ll make up a small drive shaft and mount a bearing carrier if I need to angle the PTO shaft. I still have lots to think about.
dilligaf13
34
south, florida
Have you thought of mounting it in the rear, maybe something like a M756 or even between the frame rails? A couple guys on here have done really nice mount jobs in various places on the rear of their bobbers and that would take care of any weight issues on the front axle. I mounted a warn 18K on the rear of a bobbed 5 ton a while back and it worked out nicely (not that the 5 ton would have cared where I mounted it)....
779
20
Springfield AR
No I thought that would be too much work for what I want it for. I am not going to put those rollers back on and am looking at lighter options for my front bumper. That winch is so much lighter without the rollers installed. I am entertaining a lot of ideas.
cattlerepairman
3,242
NORTH (Canada)
My personal opinion is that a winch installed between the frame rails, driven hydraulically, with a cable that can be run out the front or the back, as needed, is the most versatile setup.
It does not even need a level wind. The cable just has to pass between two tighter fitting pulleys that lightly compress with an air cylinder, creating enough tension on the cable that it always winds in under load.
If I had the fabrication skills, that is what I'd go for.
