- 4
- 4
- 3
- Finger Lakes Region of New York
Returning back to MV restoration to provide constructive distraction now that I've retired. Recently purchased a 1951 M37 and expecting delivery at the end of next week. According to the seller, this vehicle has been in dry storage for the better part of 28 years. True or not, the truck is solid and relatively unmolested; however, rear frame rails are bent aft of the cab. It comes with a solid donor frame for future change out. Obvious work will be brake system, fuel tank and electrical system overhaul first, and then I intend to drive and restore over time. As stated in the title, this post is all about the electrical system. I'm not a purist, but also see no point in making changes when things work well as manufactured. I've operated under this premise with every other restoration undertaken and was never disappointed. Unfortunately, whomever put this truck into long-term storage had other opinions.
As best I can determine from pictures, the 24-volt distributor has been replaced by a 12-volt civilian version. That indicates the oil pump was also exchanged for its civilian counterpart. The 24-volt generator (assumed 25-amp) remains, as does the associated voltage regulator on the firewall. I have no idea if the 24-volt starter is there. Oil bath air cleaner is absent, and based upon carburetor airhorn section the ETWI was also exchanged for its civilian cousin (ETWI was found it the bed). Lastly, two ballast resistors with light-colored wiring are mounted to the exterior of the generator voltage regulator bracket. My conclusion based only upon what I can see in pictures is that the 24-volt electrical system is in place, and only the distributor and coil are 12-volt. I feel this is reasonable given the presence of the wired-in-series ballast resistors. I would normally not buy any vehicle without inspecting in person, but I'm disabled from military service and have travel limitations that precluded me from that. All that said, examining pictures from the current owner are the best I can do until the truck arrives. It's been quite some time since I've worked on 24-volt systems and was not an expert even then. I'm hoping those of you who have stuck with your passion for MVs can give me some much-needed counselling!
Is the 24-volt generator still rebuildable, meaning all necessary parts are available to servicing shops?
Same question for the 24-volt starter. If memory serves me correctly from my M37B1, changing to a 12-volt starter means changing out the flywheel for the correct number of teeth.
I found a solid state generator voltage regulator and wondered if any of you have modified your 24-volt system with one? Is it a good upgrade or should I steer clear? Is it just a simple swap part-for-part?
How well does the system work if I leave everything at 24-volt potential but the distributor, coil, etc.? I would probably not use ballast resistors and replace then with a solid state 24- to 12-volt DC regulator with adjustable/fixed amperage output--3 ohms target/minimum!
Would it be best to eliminate the OEM circuit breakers and add inline fuses on critical circuits? Although I never had a significant wiring issue, I recognize they happen. I would completely rewire with the frame swap so this would be an interim and preparatory step in the interest of safety and dependability.
Still have crimping tool from military service for Packard connectors. I plan on primarily employing Packard connections to the greatest extent possible in the rewire; however, I'm a great fan of using marine-grade tinned copper wiring vice the military wire. Does anyone have strong opinions to the contrary? I'd welcome any thoughts or recommendations. My only reason for preference comes from experience building harnesses for cars and boats and this wire holds up extremely well.
Finally, has anyone else had success with frame straightening? Only time I've had it done professionally was on my WDX and insurance was paying for it (someone hit me). Any other time was using a frame machine I had access to. Since that frame machine is now in Colorado and I'm in New York, it's no longer an option. Best I can do now is use a HD construction equipment trailer as my pulling/anchoring base with jacks/jack stands/steel I-beam to keep the axles off the ground. Pulling is easy with a chain binder, and pushing with jacks from the trailer as a base. Also may have the option to use an offroad forklift as a relocatable bracing base to push or pull from. I know not to heat frame rails unless a last resort. In any case, the adjusted areas will be braced by welded steel patches. This is just so I can keep driving the truck while getting the donor frame prepped for swap out. I really do love these trucks and missing having one to drive. My wife thinks I'm crazy!
Thanks for any wisdom or experience you care to share. Any and all will be greatly appreciated!
Best regards,
David
Best regards,
David
