24 Volt LED Questions
WildernessJeep
89
Huntsville, Texas
So I'm preparing to get my M936 (waiting on EUC since 8.21.2019), and I have some 24 volt system questions:
One of the best upgrades I did on my jeep and F 250 was changing every bulb over to LED. The Jeep took a digital flasher, and the F250 fast flash can be turned off in the computer. Both of them are super-bright now, both inside and out. But the M936? What to do? Am I to understand that every bulb on the whole truck is actually running on 24 volts? The headlights and everything? I was planning to change the dash lights out to LED, but do I need to get special 24 volt LED's? I see they have 24 volt to 12 volt converters on Amazon for cheap, and was planning to do that so I can charge a cell phone and stuff in the truck, but would I need to rewire every light to take 12 volts? I'm really confused.
Also, if anyone knows if I can operate the crane while driving the truck (yes two operators) that would be a bonus question answered.
98G
Former SSG
4,170
You can change all the lights over to LED without converting to 12V. Yes, all lights are 24V. Not sure if you'll have flasher issues or not.
No, you can't operate the crane while driving. If the PTO is engaged, the driveline is not.
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
Member swampdonkey has the LED kits for the 939 series trucks. If you put LED bulbs in those dash sockets they will be too close to the covers and will melt them. You need to space the sockets back
MWMULES
345
DESOTO, KANSAS
LEDS in 24v when they first came out were $$$$ but now they are about the same a 12v bulb. Google is your friend, a lot of LED bulbs out there now are muti-volt with a range from 12-24VDC and 24V DOT headlights are there too. Using a 24 down to 12 converter is great for cell charging and other 12v options you may want to add. Upgrading to LED headlights on my MV's was the best thing I ever did, oh and seats too! https://www.amazon.com/TURBOSII-App...words=24V+led+headlight&qid=1577637119&sr=8-6
