24 Volt to 12 Volt Step Down
countywacker
PA
Hi,
I have to install a 24v to 12v step down on a duce and a half. The truck is currently being used as a brush truck and we need to run the normal 12v items such as radio, siren and red emergency lights. I need a unit that has at least 5 connections.
I've looked around online and there is a ton of options. But is there converter that anyone favors before I purchase?
countywacker
PA
Let me amend my last post. I'm thinking of just running a connection from the voltage converter to a 6 position fuse block.
So I will not need a multiple connection converter. Just a single should work.
jkcondrey
140
Rutherfordton, NC
There are a multitude out there reasonably cheap. Just get one that will cover the amps and watts you need. Some folks add a second 12 volt alternator on as well. If you run off one battery keep it mind it WILL cause an imbalance eventually. Depends on your usage really.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
I have used Vanner and Newmar, both good units. First you should figure your current draw, then find one with a tad more capacity.I may have a spare Newmar, if interested PM me.
countywacker
PA
I tried PM'ing you and it said your box was full.
Cab you send me the info on the unit you have for sale.
2deuce
147
portland, oregon
How is it done with a 12 volt trailer... brakes and all? As far as creating an imbalance from working off only 1 battery, can you move your batteries around if one starts showing a little lower charge when full?
rustystud
2,729
Woodinville, Washington
If you use a "Vanner" it pulls power from both batteries for your 12 volt circuit, and feeds both batteries when charging.
