24V Battery Tender hook up?
BERZERKER888
892
Daytona, FL
which battery posts would a 24v 2.5amp battery tender be installed on... stock 4 battery OEM setup....
Ronmar
7,056
Port angeles wa
Doesn’t matter which really as long as the battery terminals have good connection. connect +24 to one of the two terminals near the frame and connect the ground lead to one of the two terminals farthest from the frame. since there is a 12v vampire load, if this is for a long term storage, I would disconnect the 12v lead from the end of the pigtail that ties the 4 middle battery terminals together.
When you pull 12v out of the middle of a bank that is only receiving 24V input, it causes one battery to undercharge(0-12v) and the other to overcharge(12-24v)… The dual voltage alternators prime function is to compensate for 12v being pulled out of the middle to try and keep the batteries healthy And balanced…
And of course for overall health of both batteries and alternator, lose 2 of those batteries(4 is gross milspec overkill). Keep one inner and one outer and the alt will have a much easier time keeping them in a happy place…
ramdough
1,729
Austin, Texas
Just throwing this out there….
If you did a 24v charger, I would have a battery balancer so you do not overcharge one of your batteries.
I have a balancer (not installed yet), but I have mine for another reason.
For my charger, I have a two bank 12v Noco charger. Each charger bank is independent so I have one bank set between 12v and ground while the other bank is set between the 24v and 12v. It was a bit odd connecting the hot from one bank to the ground of the other on the charger. The advantage of my setup is that if one bank is low, it will independently charge to capacity without overcharging the high batteries. One bank may be floating while the other is still charging. The setup works great! Plus, 12v chargers are usually cheaper.
Just my 2 cents.
Ronmar
7,056
Port angeles wa
Just my 2 cents.
But worth more than .02…
