24V help (disconnects and inverters)
zguinness
Holden, LA
Looking for input on correct placement of disconnects and inverters in a 24v system. If I want to install a keyed battery disconnect and a 24v-12v inverter is this the correct order?
Disconnect between batteries and starter and inverter on 24v leg out to the battery switch?
For the inverter can I just run a wire from the battery terminal at line 6 to the inverter and then a ground wire from inverter to a suitable ground?
M35A2-AZ
387
Tonopah, AZ
That looks right to me.
Put the Battery Disconnect on the ground and the 24v inverter on the POS side and your good to go.
