24v to 12v dilema
85-m1028
costa mesa ca.
I have a 98 military hmmwv turbo 6.5 diesel drive train I want to put in a blazer project. I have everything radiator to t-case "including all the wiring and computer box"
this engine and components run with 24v and everything on the blazer is 12v
do I just need to hook it up 24v and then step it down to 12v?
any suggestions on how to best go about this??
Blythewoodjoe
56
Blythewood, SC
Put the stock HMMWV dual voltage alternator on and you'll have all the juice you would need. If I understand your post you are putting the HMMWV engine in a chevy? You wouldn't be changing anything on the engine that way. I put one on my deuce.
mangus580
282
Western NY
Like joe said... I would use a 12/24 alternator. They bolt right on the humvee engine. Matter of fact... If you are running the computerized engine, it may already have it!
mangus580
282
Western NY
it has a 'dual voltage' regulator. Do some seaching... me & joe both put them on our deuces, and Joe has a thread with pics.
85-m1028
costa mesa ca.
with a dual voltage alt do I connect two batts in series and run them like the cucv set up essentialy having one alt doing charging duties instead of two??
heres what I'm looking at
mangus580
282
Western NY
The dual voltage, you will need 3 batteries. 2 used for 24v, 1 used for 12v. Looks like you have a 24v alternator? What transmission is that, do you know?
JasonS
144
Eastern SD
Do you really need three batteries? Can't you tie the 12V out from the alternator to the mid point of the existing two batteries in a 24V system?
ida34
33
Dexter, MI
You should not fun the 12 out from the alt back to one battery. The two batteries need to be balanced or the 24 volt side of the alt will fry them. When one batter is charge more than the other one the alt works hard to bring the weak battery back up. When it does so it over charges the other battery. I will be using a small motorcycle battery for my 12 volt side. It will be enough to handle all my 12 volt needs and small so I can hide it away somewhere.
JasonS
144
Eastern SD
I don't see why it wouldn't work. I have done the same thing with series capacitors in power supplies (FWB doubler). Putting 14V on the first battery and 28V on the series combination should serve to better balance the batteries.
ida34
33
Dexter, MI
I am sure is you did some fancy electronic regulation it might work, but as I said, if the batteries get unbalanced then you are going to fry them both. Its your batteries and your truck so do as you wish.
JasonS
144
Eastern SD
Alright, ignoring for the moment whether or not this particular alternator is capable of the desired task... There will be no imbalance by supplying 14V to the center connection between two series batteries. The voltage there is already 14V (for good batteries).
Take it to an extreme: What if you could charge each cell independantly at 2.3V. No cell would get too much or too little charge/ voltage. Would you still argue that there is imbalance?
rmgill
14
Decatur, Ga
So you're charging the first battery with 12 volts from one source point and the second one with 24 volts across both batteries right? How do you proportion the charging current. Because your 1st battery will have twice the current running across it no?
JasonS
144
Eastern SD
No, not necessarily. Lets say that you apply 14V to a point that is already 14V; nothing happens; no additional current will flow. I don't know how the current will share upon startup; probably depends on if one battery is weaker and discharges more than the other. Maybe someone knows more about how the alternator is developing dual voltages or how much it can source?
