- 1,845
- 51
- 48
- Berkeley CA
Some one posted this a while ago but I lost the link to the poster.
Default CUCV Fuse Box Layout
There are some errors in the TM diagram for the CUCV fusebox.
I will attempt to point them out as I find them
Here is a "clean" fuse box with all the proper fuses and labels
ITEM
2 - Hazard Flasher
3 - not used except for the M1010. The M1010 uses it for Ambulance Accessories
4 - no such fuse the diagram is wrong
5 - 20amp Heater Fuse - Controls the heater. Also controls the GEN1 idiot light, 4x4 light and the Oil Pressure light
6 - 10amp Stop - Controls the regular stop lights and the Blackout stoplights
7 - 30amp Headlight - Controls the headlights and also feeds the stoplight, xxxx lights
8 - 25amp Wipers - Controls the wipers and washer pump - Only fuse that is hot with the key in the ACC position
9 - Flasher - turn signal flashers
10 - not used except for the M1010. The M1010 uses it for the Gas Particulate system.
11 - 15amp Horn
12 - 10amp 24v - Controls the GEN2 light, 24v sides of the GEN2 relay and the voltmeter
13 - 5amp Instrument Lights - Controls the lights for the instrument cluster, heater switch and voltmeter
14 - 30amp Flasher - Controls the hazard and turn signal flashers and the backup lights
15 - 20amp Ignition - Controls 12v side of the Voltmeter and GEN2 relay, transmission kickdown, low coolant and water in fuel light
16 - 20amp Tail Light/Courtesy Lamp - Controls the park lights and the underdash courtesy lamps
17 - 20amp Engine Control - Controls the sealtbelt buzzer, dash lights for the tempeture, low coolant, brake and water-in-fuel. This fuse also supply's power to the GP controller via circuit 39G (diagram E-7)
18 - 5amp Blackout - Controls the B/O markers and B/O headlight
ITEM
2 - Hazard Flasher
11 - 15amp Horn
