250 water pump gasket
Looking for the water pump gasket for the cummins. any sources out there? having trouble locally finding these. they look like a copper ring about 4-5" in diameter aprox 1/4" wide.
I hated to mess with the pump for this reason but i Put new belts on the M819 the other day and the water pump had to be moved. :(
Allways somthing. only dripping about 2 drips per hr but i cant leave it like that forever as im afraid the antifreez might wash off some of the grease and oil that ive been saving on the underside of this truck.
377
Owatonna, MN
We installed a new water pump gasket for the exact same reason you did- replacing the belts. We purchased ours directly from N Power Cummins in Minneapolis, MN. I'm sure Will Wagoner can find the part # for you if he chimes in.
Now is a good time to grease your fan hub- I notice alot of the grease zerks on these are strictly ornamental! Take the cover off and pump out the old grease while it's easy to get at.
Andy
timntrucks
146
Ponchatoula LA
i need that gasket myself so ill watch this post to see if any nice member will chim in with a parts number. thanks TIm
WillWagner
3,163
Monrovia, Ca.
There is a parts manual in the TM section. I;ll try looking it up onQSOL right now, stand by...
The copper gasket should be p/n, 130240..still agood number. FYI, coat the gasket with never seize. It makes future adjustments easier, and sometimes a bit more leak free.
Thank you Will. i'll try the dealers with the new info and let you know what i find.
