3 cylinder M35
SETOYOTA
435
georgia
When you start this truck up it like its running on 3 cylinders. You have to hold the pedal to the floor to keep her running. After say 2 minutes or so she will come up to speed and idle, run and drive fine. It goes down the road fine .
This all starts over after you park it overnight. Any ideas?
Fuel Filters maybe?
Chuck
poppop
39
Brooklet, Ga
Sounds like fuel is bleeding back and air in the system. Is the intank pump working. My dump truck does this but the tank pump is dead. It fires on one cylinder and gradually picks up the rest. Have to spin it a while to get fuel pumped up. A couple friends had trouble with theres and found rotted rubber lines letting air in and fuel leak out.
Djfreema
Santa Clarita, Ca
Go through and tighten all the fuel return lines between the injectors and if you have a flame heater, tighten all those lines too. I did that on my last truck and it solved the problem. My current truck needed new o-rings in the flame heater nozzle, it helped but the o-rings arent the correct ones. If you have the clear return lines you'll be able to see bubbles going through the lines after the engine is shut off and the fuel starts to drain back down. I replaced all my old return lines with black air lines from napa and got all new brass ferrules from Lowes.
SETOYOTA
435
georgia
The in tank fuel pump is working fine. Thanks for the help. I will see if tightening the fuel lines and changing the filers makes any difference. It has no visible fuel leaks.
Chuck Herbert
