- 1,108
- 1,226
- 113
- Basehor, KS
Many folks are looking into converting a 15KW to 60KW Genset to single phase 240/120 VAC.
The ability to do this through the reconnection board is limited to the 004A, 005A and 006A and is not recommended to be done by the average Genset Owner due to the possibility off getting the connections wrong which will result in an absolute spectacular firework.
Basically, the firework of all fireworks, the grande finale.
To avoid this spectacular firework, we have been recommending to our customers to use a Delta / Wye Transformer with at least 300% of the rating of the Genset to be connected.
The best source for those transformers is eBay, as they are typically used in industrial environments and with the continued de-industrialization of America, are plentiful on eBay and can be found in the US$ 200 to US$ 500 range plus shipping or pickup.
However, a word of caution with eBay,
on a recent purchase by one of our customers, the eBay seller had listed the Transformer to be a Delta / WYE but it turned out to be a WYE / DELTA. Those can be used, but require a re-connection / reconfiguration on the secondary side from Delta to Wye to wind up with a WYE / WYE Transformer.
Peter
Peter
