302 vs 331 Holley carb
M37keppy
77
Eldridge, Iowa
Hi all, I’ve been wondering if you could use the bigger sized jets for the Gold Comet 331 on a Gmc 302? Would it produce more power, would it screw up the shifting of the auto, or would it cause other problems? Just got to looking at the two using the same carb and thinking. I know that the last statement can get me in trouble sometimes. :D
73m819
329
gainesville, ga.
Maybe get to the Governor a bit quicker, should not affect the modded cad. trans, use a bit more gas, that's about it, the old cast iron cad trans should handle 400 + hp easy, since the 302 is no where near that I do not see a issue, it will shift faster due to reaching rpm faster and a bit higher vacuum draw. I would go ahead and try it, easy to go back if it does not work out.
M543A2
15
Warsaw, Indiana
I have been guilty of enlarging jets on many engines. I usually go up one or two drill sizes and try it if I am working with the stock jets. Yes, it usually yields more power depending on the situation. You can do it, then after driving a while, pull some spark plugs and see if they are blacker than they should be. If you see this, or blacker than normal smoke out the exhaust, then maybe you went too far. If quite white, you can go another drill size. If I go too large, I then carefully lead the jet shut and re-drill it to the smaller size I want to try. There are those who yell out that you cannot do this leading in and drilling out but they are welcome to come down and see how it has worked on my power units in tractors and vehicles. The new alcohol content fuels are a key cause here. To get an older engine to perform like it did jetted for the pre-alcohol blend fuel, more fuel needs to be put into the air/fuel mixture. Many times bringing the timing ahead of factory spec, but not to the point it rattles, helps power greatly also on the alcohol blend fuel. I cannot see it affecting shifting or anything else.
I have an M880 I modified the carb with jet drilling out to run E85 with good success. E85, and to a big extent the 10% blends eat up the rubber in lines, fuel pumps and carbs made for the original fuel so I despise alcohol blends in older vehicles. Leave one set too long with it in them and see how the inside of the carb is literally destroyed with corrosion. I run the 91 octane alcohol-free fuel in all older motors. Yes, it is more expensive but I think that balances out over the cost and frustration over the many destroyed components I have had to constantly repair/replace due to the alcohol. On the farm many vehicles like combines and tractors will sit idle for months so this kind of damage is unacceptable. The bean oil content diesel is no better.
rustystud
3,392
Woodinville, Washington
I have to make a 3 hour "pilgrimage" to get my "pure gasoline" for my truck and other small engines. It is a royal pain !
73m819
329
gainesville, ga.
Lead plugging/redrilling was done all the time back in time, no big deal, when Swiss and I get around to it, we are going to use epoxy instead of lead to do some jet playing from the m62 carb, We already put shaved heads (3/16) on to raise the compression, it seems to start better.
rustystud
3,392
I wouldn't use "epoxy" with the gas we have nowadays. It might eat it up. I know it will eat aluminum. Actually might eat up the lead too.
Floridianson
2,538
Interlachen Fl.
They make epoxy made for gas tanks. I keep at roll of it in my truck tool box. As for jetting I look at the ground strap on the plug and there should be a visible color change heat line right at the curve. Farther to the tip is colder / rich and farther down past the curve down is getting a leaner hotter fuel /air mix but to hot.
