AK_M1028
- 0
- 6
- Fairbanks, Alaska
I just bought a set of 325/85R16 Michelin XML tires for my M1028. Michelin recommends a 9" wheel, but doesn't offer any alternatives. The data I've seen says these are 38.7" x 12.9" tires when mounted on a 9" wide wheel. I am in the search for wheels right now. I heard that these tires do well aired down and will hold the bead even down low, so I don't plan on going with beadlocks.
How do you think they'll do with 8" wide wheels? Will they hold a bead better aired down on a skinnier wheel? Or should I try find a 9" to 10" wide wheel to get better contact area? I've read that the load capacity is 5,070# @ 65 psi to 3,600# @ 45 psi. I should be able to keep them somewhere between 30 and 40 psi for everyday driving.
Thanks in advance for your advice and comments.
