3D Bracket for Dual USB charging port and lighter socket on M923A2
madcroc1
deerfield beach, FL
Hello fellow SS... I just print up this bracket for a USB and Power Port in drab green PLA filament. The USB can work under 24V but I am wiring it up 12V from one battery bank instead of both..
I got the stainless steel blue sea dual USB port and lighter socket. You can get them anywhere online..
Here are the pictures of the first pass of the bracket.. I'll probably add rounded corners and I may change it to a vertical config instead of horizontal..
Let me know if anyone wants the 3D file...
Any Comments ??
TexasRam
Lubbock, Texas
Very nice.. yours is way nicer.. where did you get those components ?
Thanks. I don't have a 3d printer so I had to improvise. Bought this set of outlets from Amazon. https://www.amazon.com/gp/product/B072FJRYSK/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 . I bought a piece of 1/2" thick wood board from Home Depot. Used a hole saw to cut out the socket holes and a router to remove about 1/4" from the backside around the holes so I could thread on the socket nuts. Painted the wood to match the 383 green with Behr FS 34094. Used some metal brackets I had laying around and bent them to desired angle. Drilled and bolted everything to the underside of the dash panel.
Sent from my SM-G935V using Tapatalk
Lukes_deuce
124
Long Island, NY
Both brackets are nice. I was just looking to make a bracket for some switches in my new 923.
I would like the 3D file. My buddy used to work for makerbot, a big 3D printer company. He has a bunch of printers at home and he can print me anything up to 18" x 18" x 18". Maybe you could design a few brackets and I could print them up.
