I'm currently printing a 1" shorter version to try out. I also got some cool new OD green filament!
I was looking at the inclinometer, and it got me thinking... what is the tip-over angle of the LMTV? The inclinometer has it in the red >14°. Using the unloaded and loaded Center of Gravity (CG) listed on the data plate (dimension "B" in the chart), along with the overall width of the vehicle and tires, I drew up this diagram. "Worst case" is if you were only measuring tip-over angle to the inside of the tires, while "Best Case" is to the outside. This diagram concludes that...
- Unloaded tip-over angle is 34.6-45.5°
- Loaded tip-over angle is 30.5-41.1°
In either case, you should be able to max out the inclinometer (26°) without going over. (This is all calculation based, assuming the CG listed on the data plate is accurate, or at least on the conservative side of wrong.)
As I mentioned in another thread, long ago, I'd really like to conduct a couple experiments:
1.) Weigh the truck at scales that record each tire (or at least each side), then drive on top of something (e.g. cinder blocks?) of a known height and calculate the actual CG based on the weight shift measured.
2.) Pick the side of the truck up and actually tip it over, while restraining it from being able to go over entirely (e.g. chain down the lifting strap spreaders, put a long square tube in the low-side spreader receiver so it can only tip over so far, etc.)
