3KW TQG MEP-831A
LuckeyD
388
Vilseck, Germany
Good Day: All the manuals you need to keep your 3KW TQG operational. There is an updated manual but it is not open for the public. It had something to do with the vendor of the gen set the government obtained it from. Issues, Governor being messed with, exhaust breaking, flames from the exhaust muffler, A8 issues, loose electrical connections, incorrect pull starting. Recommend reading the manual and set it up correctly for the desired output. Fill the oil lever at the dip stick, just stick the dip stick in and pull out for oil check, and the oil filter is a screen and should be changed if it gets a hole in it. Clean every other oil change. Keep air filter clean. Runs at 2 speeds, low load, and high load.
