4-Door Deuce and a Half/Mega Cab
moparnut
santee, cal 92071
Check out what we did last summer to a M35A2. We made it into a 4-door with hydraulic rear steering, put M35A3 rims, 48" tall tires. Check out my picture album and let me know what you think!
moparnut
santee, cal 92071
I really didn't keep track of hrs. But it's alot easier then you would think. 5 weekend days 10hr. each probably another 60hrs. in the little things. It has 24voltdc to 110ac inverter (800 wt) a3 rims seats from a hummer, going to install air ride seat just need to clean it up. But it has been a real learning process, and fun it gets looks and great commets no matter where I go (even get thumbs up from local P.D.) Sorry for the long reply.
moparnut
santee, cal 92071
Love the 4 wheel steer!! Nice truck.
it really shrinks down the turns. BUT YOU DO NOT USE IT DRIVING DOWN THE HWY!!!!!!!!!!! it makes you really pay attention to the rear wheel postion.We are making a self centering system, just in the works right now. Thanks for the good commet.
A
A/C Cages
Guest
Sweet truck, take some close up pics. Give the rest of us some tips on what you have done and likewise we can give you tips too.
God knows we all made some mistakes over the years and wish someone would have shown us different..lolrofl
Very nice. Can you elaborate on your rear steer system...hydraulic, electric, joy stick, etc. What are you using on the front steering. Nice truck, looks like A LOT of work.
moparnut
santee, cal 92071
A friend of mine sold me a 12volt hyd. pump (3500psi) with a tank atatched that he used to make hyd hoses for his bussiness, from there we ran wires through a main power switch then to solenoid and relays to a left right joy stick to a control valve mounted just above the rear axle. Then ran 2 hoses to a two way hyd cyl. that i got from psc. it was a kit but i left out some parts that I already had to save money. If you want send me your email info and I can send you a picture of the steer axle. Right now it is out because it broke the long alxe shaft. It has a solid axle right now but I'm looking for long and short axles so i can reinstall it..Front steering is stock looking into using 5ton pump onto the front of the injection pump housing, just remove cover plate and figure out how to make it work. here's my email burnouts@cox.net I can send you some pics of it also thinking of selling truck. Thanks for the good commet on it.
