419 wiring harness replacement update and help?
majkowskid
49
The Great State of Texas
Replacement wiring harness update
She runs!
Had some weird issues with a popping heater fuse at first when I was turning the master light switch to full running lights but I think I have that worked out.
I believe we had some of the 4 pin connectors behind the ignition switch misconnexted They are labeled e1-e5 and c3 on the new harness.
I think we have those connected correct as about 85% of everything is working.
Things that aren’t working:
-Turn signal switch. Does nothing. This didn’t work prior to mouse damage.
- horn. Also wasn’t working before so may have been prexisting. Going to try to try the horn with battery tomorrow.
- volt meter. Used to work. Not now. ??
- all warning lights above speedo. Nothing illuminates. No brake, no pro light. Nada. Those used to work.
Then I have a really weird issue. When I turn the master light switch to full run (all the way to right) all lights work… high low beam etc. but the hazard relay under the dash just clicks continuously. The button actually turns the lights on and off, but the relay just keeps clicking. Very strange.
If you have any suggestions let me know!!
