'44 GMC CCKW Restoration
Day Radebaugh
33
13
El Dorado, KS
Newbie from Kansas has acquired a truck that has been described as a '44 GMC CCKW. I have no documentation. The truck runs and I intend to restore it. My first question is the shift pattern. The main box (transmission) is 5-speed, with 1st down and to the right, the rest if regular H-pattern. However, the transfer case has me baffled. It has 2 levers. When both are forward, I appear to be in 6-wheel drive low. When left-most lever is back, I think i'm in high-range.
Does anyone have a shift diagram for this truck?
Second question: I will repaint this truck, and want to put Olive Drab on it. Is there a good source for this paint?
Have attached a picture of the old girl at work on the farm. She's a great old truck.
Thanks very much.
Day Radebaugh
33
13
El Dorado, KS
I will look for the data plate. Can you tell me where the frame number is?
My understanding is that the truck was originally an open cab, but was in an accident, and someone replaced the cab. The truck was used to move houses out here in El Dorado, KS.
Day Radebaugh
33
13
El Dorado, KS
Are your data plates missing? What is your frame serial number? 1944 is too late for closed cab.
RAPCO for the paint you need.
Many thanks for the pic of the data plate. The truck does not have this plate. Do you happen to know if I can get this made somewhere?
Thanks for the information. I managed to get the left-hand lever (range selector) into high range, but can't seem to move the right-hand lever so as to disconnect front-wheel drive. Is there a trick to doing this?
Day Radebaugh
33
13
El Dorado, KS
Many thanks. Will give it a try.
Huge thanks for that suggestion; it worked like a charm. She drives fine now.
Have attached some pix of the old girl. I'm having her hauled off to the painter today for a new paint job, and then I'll get her back in my shop and start on the cab interior. It's still 6V electrical, and starts fine, although I may convert it to 12V. Original engine, as far as I know. As I mentioned, the cab has been replaced. I included a picture of the data plate in the cab.
NDT
7,479
Camp Wood/LC, TX
It appears the data plate might be correct for that chassis. The "352" part of the number is GM code for short wheelbase, only about 10% of CCKWs were short, and yours is. The B1 means cargo without winch, no surprise there, all shorts were cargos. The 218119 is the production sequential number, it is possible it's a 1944. Sounds like whoever swapped the cab, moved the data plate across to the replacement cab.
Wolfen
160
Woodburn Oregon
Thanks very much.
Following
Day Radebaugh
33
13
El Dorado, KS
Thanks for the information. I will go over to the paint shop, where the truck is now, and get the frame serial number. I find it fascinating that this truck may have been brought back from Europe after the war. I'm supposing that this may have been to restart the domestic truck transportation industry, which was probably suffering from the inability to buy any new trucks during the war.
NDT
7,479
Camp Wood/LC, TX
The story goes like this. The 1941,42, and 43 trucks that went to war got consumed and never returned. The 1944 and 45 trucks were considered the latest and greatest and those that shipped to Europe theater were given to France, Norway, Belgium and others after the war. They kept those until the 1970s, usually rebuilding them at some point. When the rebuilds occured, trucks were built up using the best parts on hand, resulting in “deuce salad”, or late trucks with early features or vice versa. In the 1970s, auctions were held overseas and many trucks were brought back by companies such as Southeastern Equipment in Augusta. Yours could be one of these, or for sure the cab. Some trucks never went overseas, and those were sold off after the war, and at the latest, the 1950s.
