4a032 bellhousing bolt pattern
m139h2otruck
NH
Is the 4a032 bellhousing a standard SAE pattern? Need to know, as I may be able to get a pump end that bolts to a standard SAE bellhousing for use on the water truck. Would be able to use the 24 v truck system to start the engine and direct plumb the gas lines into the fuel pump for fuel to the 4a032.
