- 4,640
- 28
- 38
- Cambridge, Ohio
Hey all,
First off, I did a search but couldn't turn up anything specific to my issue. As some of you may know, I recently acquired an ENG-3 Lubricating and Servicing Trailer. I've been playing with the 4a032 that runs the air compressor in the trailer. After cleaning the control linkage and unloader valve and the cylinder that idles the engine when unloaded I have it working better, but not the way I would like it to work. When the engine is running making air, it seems too slow, and when it idles back after the pressure is met it's not idling back far enough. I'm almost positive it's something in the adjustment of the control linkage and set-up of the governor. I was looking through the manuals for the engine and found the sections about the control rod, but I am confused...please help.
Under the "Control Rod Installation" section it says in step two, to push the throttle lever to idle.
Under the "Control Rod Adjustment" section in step three it says to hold the throttle lever against the stop. WHICH ONE? Am I supposed to hold it to the idle stop or the high speed stop??? I have to assume that it means the idle stop like in the installation instructions.
See the pictures provided.
The problem is, when it's installed and adjusted with the throttle lever to the idle stop, there seems to be no room left at all for the governor arm to move. I'm not familiar enough with the operation of these egines to know for sure...but I also don't want to just try it and then break something.
Also, under the instructions for adjusting the governor, in step 6 it tells you to turn the screw until the engine "surges" What exactly is that supposed to mean? Get a surge of speed? Start slowing down and the surging back up again??? It's kind of confusing to me. I'm not trying to make it run at 3600 RPM's just because that seems kind of fast, but I would like to see it running about 2000 to 2200 RPM's under load and idle down to around 1000 when resting. So far that's unattainable. The best I can get is about a 300 RPM difference in load and no load speed.
I thought I would let this one up to the experts. Thanks in advance.
