4inch lift brake line help...
PAm1009
hatboro,PA
In the middle of doing my 4inch rough country lift and need help with the brake line brackets .. Did you have to buy new Brake lines? There's no slack on the steel lines inside the frame. Did you even use those brackets they don't look like there adding that much extra room.. Thank you much
kyle
Awol
459
MA
When I had the 4" on my 85 K10, the rubber lines running to both front wheels and the rubber line that connected the rear axle to the system needed to be replaced. I used extended braided line for the front wheels, and made a bracket to lower the factory rear line closer to the axle housing.
I would recommend changing the rear axle line. When I made the bracket to get it closer, it still would want to stretch it when the axle would flex.
481
10
Charlotte, MI
Yes, if you keep the stock brake hoses you will end up yanking them out. ORD has a nice set of longer front and rear brake hoses for this application. No need to move brackets.
Whitfield
Richmond Virginia
I've been shopping these for 2-3 weeks and will be ordering the ones listed above tomorrow. Looks like the price and quality is unmatched. Will also be ordering the value priced shocks from them as well. Other then lack of corrosion protection on the chrome shock shaft and painted housing they are a good deal.
