4L80E Fresh Rebuild in Limp Mode w/ codes 73 & 87
gotaconvoy
19
FL
Howdy. I just finished a 2 year rebuild and took the Humvee for a test drive after getting it registered. One aspect of the rebuild was having the transmission rebuilt at a reputable transmission shop (bench rebuild with no test drive at time of rebuild). During my recent test drives, the trans shifted from 1st to 2nd, then stayed in second the remainder of the drive.
Truck:
1996 M1097A2
6.5 non-turbo
4l80e
Codes:
Trans light comes on with key on / not running, and goes off once the truck is running. Using a jumper at the test port I get codes 73 (PCS Circuit) & 87 (High Ratio Error).
Diagnostic steps taken so far:
Using wiring schematics from the 4l80E manual (https://gear-report.com/wp-content/...ment_7_4L80E-Transmission_Troubleshooting.pdf), I verified all the appropriate voltages and grounds were present at the TCM, trans relay and breaker.
Followed the DVOM diagnostics steps for code 73 as outlined on page 101 of the TM. Basically confirming continuity in the two wires between the TCM and trans plug, then confirming PCS resistance (4.3 ohms). Everything had continuity and ohms were within specs but the flowchart stops there.
I do not have a tech2 scanner, or any other equivalent to interrogate the TCM in order to follow the diagnostic steps for code 87.
Points to note:
After purchase (govplanet), I think this was a parts truck in a depot somewhere that slowly got cannibalized and when it was time to sell they threw whatever parts they had lying around back into it. I'm pretty sure the trans I bought it with may have come from another truck due to it being halfway installed with missing hardware and very much inoperable.
Additionally, the TCM part number in the truck is TCM-2100AA, which all the research indicates is for a turbo engine, and mine is naturally aspirated.
Next steps:
Here's where one of you lovely folks hopefully comes in because I don't know where to go next. I was about to buy some tech2 clone, an old obd1 port, and try and talk with the TCM but I figured I'd ask around first before going crazy. Any ideas?
NDT
7,076
Camp Wood/LC, TX
Did you read page 126? Points you right at the TISS and TOSS for 87 ratio error. These two sensors are known to give issues. The code will cause the limp mode you're in. Suggest you focus on these sensors and related wiring.
gotaconvoy
19
FL
I did read it, but the actual troubleshooting steps require a scan tool which I don't have. I didn't know the TISS/TOSS are known issue items, so I will definitely focuse my attention there. Thanks!
Mogman
10,161
Papalote, TX
You can still ohm out the circuits, they should read aprox the same and nether should have a ground reference.
Note, I did have a bad TCM not too long ago that gave a code 87
gotaconvoy
19
FL
Yeah, after reading the last message, I found 2 sensors on rockauto for $11. I'm going to just swap them out, verify continuity in the wires and hope for the best.
Which TCM did you have and where'd you source a replacement?
Mogman
10,161
Papalote, TX
It was the older style with the EPROM, I had a spare bought off the internet used (civy source)
gotaconvoy
19
FL
That is going to be my next question if the speed sensors don't pan out. Will any 4L80E TCM from a non-turbo work if I'm able to find a diesel civ truck of the same vintage? Side note - I find it odd my non-turbo truck has a turbo TCM as it is.
Mogman
10,161
Papalote, TX
You would need to find a 6.2L TCM with the 4l80 as the 6.5L had an ECM and will not work,
Autozone used to carry them but I think that source has dried up.
gotaconvoy
19
FL
The TISS / TOSS wiring had continuity from the TCM to the sensor plugs on all the wires. I changed both sensors but still the same issue where it goes straight into limp mode after the first successful 1 - 2 shift, and throws codes 73 & 87.
Now I have to decide whether to spend money on a scan tool setup, or throw a TCM at it and hope for the best.
gotaconvoy
19
FL
Did you verify: nether should have a ground reference. Meaning are any of the wires touching ground?
Yes - with everything hooked up and TCM unplugged, I'm only getting continuity to ground at pins C1 & C2 which are the two system grounds.
Interesting observation just now - after disconnecting the battery for over an hour, then checking codes without even starting the truck, let alone drive it, code 73 pops up, but not 87.
