- 545
- 739
- 93
- Canton, PA
Hi Everyone,
I am trying to diagnose the concern with my transmission and wondered if someone can help shed light on the matter.
When I am shifting up through the gears from 1st through 5th, there is no grinding. Very smooth. But if I am in 5th gear and want to downshift to 4th, there is some massive grinding. But it only occurs within certain parameters.
For example, if I am on a level road and I am in high or low, if I want to downshift to 4th gear, if I am going more than 15 mph or the rpms are above 1500, it grinds hard into 4th. I always make sure there is enough time to downshift and I have even tried double clutching and it still does it. If I am on flat ground and I am going below 1500 rpms and or 15mph, it does not grind.
If I am on a hill with the truck and I get to about 1600 to 1700 rpms, I can downshift to 4th and will not get any grinding whatsoever. It almost feels if there is more of a load, it won't grind, but on flat terrain it will. My problem with waiting that long to downshift is, when I am on steep grades, I have to immediately go to 3rd gear or the truck will come to a hault. I am wondering if its my driving, if the speedometer is off and is why its grinding (because I am going faster than what 4th states) or if its fourth gear. Like I said, it happens only in this gear for both high and low range. I guess if I am on flat ground and I am only going 10 mph, I really don't need to downshift to 4th, but if I am at the crest of a steep hill and I want to downshift to help ease the speed of the truck, I should be able to do so without the grinding that occurs.
Anyone else have this issue? Any help on this matter would be greatly appreciated.
