5 cummins repower units for sale
hot rod deuce
Kasota, Mn
i found some 5.9 cummins with an allison trannys. there are 5 of these things in a construction magazine so i called the guy and they are 180 hp 1995-1996 model year with inline pumps there in airport shuttle busses 80-100,000 miles what do you think of that? i was thinkin maybe if any one was interested id go but all of em and get us a little better deal.
i want one, papa wants one and as does a local farmer too prolly goona go look and hear them run some time in the next month.....10 hour drive!
MattS
How much? That year would be a 12V and easily bumped up to 300 hp. But 100,000 miles of use in a bus sounds like some hard time. Any chance they have an hour meter on them? Unless you can get them dirt cheap I would keep looking.
hot rod deuce
Kasota, Mn
no there is no hour meter i could get motor and trans for 2,500. each (one or all) 300 HP? WOW now that would zip my lil deuce right along down the road...prolly rip her in half all at the same time. any way one might be able to haggel a little bit with him too. or its back to the old 3208 paper weight.
MattS
For 2500 it would be worth it IMO. If I had $2500 I could blow without getting yelled at by the finance manager I would buy one. The engine will fetch about $2000-$2500 depending on how complete it is. And the Allison tranny's are going for just over $1000.
Put a TST plate on it and start pouring the black smoke!
http://www.tstproducts.com/power_kits_trial.htm
BTW, you WILL need to use an intercooler with this motor. So think about where you will put that before you buy. <img src="emoticons/icon_smile_wink.gif" alt="Wink">
hot rod deuce
Kasota, Mn
first, thanks for the link and then
dumb question#1 whats IMO stand for???<img src="emoticons/icon_smile_dork.gif" alt="Dork">
ok now that im a fool! the cummins is like 3 or 4 inches shorter than the herc so there might be room up front or move the headlights out and get a wider and skinyer after cooler. or last but not least move the radiator into the box right beside my fuel tank (16.00 R20's dont leave room for the stock side mount tank)then stash the cooler up front.<img src="emoticons/icon_smile_idea.gif" alt="Idea">
they sure didnt wast any room, the injection pump clears the steering box by a 1/2 inch, the winch drive shaft has about 3/8 at the bell and the winch is an inch from the radiator <img src="emoticons/icon_smilie_bitchin.gif" alt="Bitchin">
thanks for the input
hot rod deuce
Kasota, Mn
well i just got it home. it runs very good and i got everything, aftercooler to driveshaft even powersteering i could have had the whole bus but didnt have room we could work out a deal if you want one,there are two more,if someone gets the whole bus to my door i will give you the other for cost, 2,000. the other two are 1993's though not 97's like mine
