Hi all! I am new to these rigs, but have some experience with larger Marine Diesels and cars. Have some basic cooling sys. questions. Thanks in advance for any help/ advice.
1- My 6000 mile 1991 truck came to me with a bad temp sender. I bought one from a local International dealer, but it is for wrong voltage. I put a little 330 ohm resister in series- now reads 216 deg. after 12 miles of light driving. Not bad- would like to get it right instead of relative. Does anybody have ohms vs. temp. of sender worked out so I can "dial mine in"?
2- My fan clutch doesn't engage. May not be a problem given my light use. At what temp should it lock in?
3- What bolts should I carry (length-thread) to "emergency lock it" (fan) if ever needed off the farm?
4- Coolant flushes can get pricy for us civilians on these rigs. What is the practical way (time-hrs.-miles) to keep the cooling system up without breaking the bank> For example- do many owners use zincs or coolant additives instead of routine drain-and flushes as on little car engines?
5- Lastly- any cooling system known "trouble spots"? for example Cat 399's and 398's tended to eat up T Stats. I am sure many parts of the cooling system are proven with some weak points. A "heads up" to us new guys would really help! Thanks!
