Willsterman
- 0
- 0
- WI
I purchased a 923A2 during the winter and GL Fort McCoy WI has a policy of not allowing them to be started while previewing in winter. Drove it home on a 45 degree day and everything seemed OK. Took it for a drive a month ago and it smelled hot and seemed to have an engine or oil line leak but I couldn't narrow it down since oil mist covered much of the lower engine and transmission and I didn't have time to delve further into it.
So I started it today, and took it for a short drive. The oil pressure was 60 psi and the temp gauge showed 180 F while I was driving. After driving about 3 to 4 miles I stopped back home and let the truck idle. The truck smelled hot so got out and could see some "smoke" coming out at the bottom back of the engine, which turned out to be coming from the 3/4" tube or pipe that appears to be a crankcase vent tube (vertical hose/pipe near back of engine in picture). I then checked the gauges again and the oil pressure was now at 15 psi and the temp was at 220 F and the radiator fan was not running. Engine oil level is fine and I can see there is some antifreeze in the bottom of the overflow tank on top of the engine.
Seems odd the fan would not be running if the temp was that high (unless the temp gauge is wrong), but it did smell hot. I am wondering if the oil pressure dropped to 15 because the oil was so hot. There could still be a small leak near the front of the engine from the engine or an oil line fitting, but I have not located it yet as everything looks a bit oily. I wouldn't think noticeable oil vapor (smoke) should be coming out of the tube coming from the top/back of the engine that runs down below the bottom/back of the engine toward the ground . Any ideas of what to check or do next?
Thank you!
Thank you!
