Well after a little research, knowing that the 5t, top mounted double, reduction axle was a standard axle used in every day comercial heavy trucks, I found the ratios that was used plus the use of a inter-axle differential or a power divider (cannot be both at the same time because both use the front differential as the base), the inter axle and power divider can be used with ALL the ratios below. this means that if we can find the inter-axle or the power divider, no matter what the ratio is, it can be used with our 6.44s, just change to the 6.44 gearing.
The inter-axle and the power divider, along with most of the ratios are long out of use and most likley found in a OLD forgotten big truck junk yard because my research shows most show "out of production, not available"
The ratios are.
4.92
5.21
5.45
5.81
6.44 -- standard 5t use
6.88
7.54
8.30
8.31
9.20
9.26 -- used in some bridge trucks
10.26 - used in the Honest John truck
