5 ton bedliner
Patgonia53
Buffalo, NY
Anyone ever put a bedliner in a 5 ton.. rather than just paint..???
Do it your self or commercial
Any experience with lineX... I have it in my pickup, and it seems to have held up well... but this is a different story
m816
Chatham, NJ
I put 3/8 steel about four ft high on the inside of mine, Does that make it a bed liner.
Vinny -Owner of the Untouchable Guntruck
Patgonia53
Buffalo, NY
i was thinking more on the lines of a "bedliner" like in a pickup... something better and more durable than paint... not quite the level of reinforcing steel
But thanks for the information
diverman555
9
Detroit, michigan
I had my entire new chevy 2500HD done for $400. I bet you could get the bed done for less. I want to do the same only have them mix in the same paint color green.
rrrr
Missouri
Here ya go. I did it on my deuce also. Here is my M932a1 with a shortened deuce bed on it.
Cost me about $100. Used a gallon of bedliner from the farm supply.
emr
25
landing , new jersey
I think using a paint roller with the standard paint keeps it original and is pretty strong too, I used rustoleum primer with a roller in the bed let dry for 3 days, man that stuff is hard and then the correct paint, Its just me but I need it to look like it did in service.
Patgonia53
Buffalo, NY
I actually need something with a little more traction... My SWAT team is going to use this for team deployment during callouts... when we roll with a big team
Beerslayer
55
Tualatin, Oregon
In this case you will probably want to use what Steve and I are going to... We have bought the product but haven't installed it. Same stuff that goes on aircraft carrier landing decks. Will do some hunting and find the web address for you. We bought it from Sherwin Williams but it is not their product.
paramedic7831
Thomasville, Georgia- USA
Ok I will add pics tom. I wanted to bed line my wheels. I started with Rustoleum from wallmart and didn’t like it because I wanted more aggressive "chunks" of stuff in it. I went with Herculiner and it was a great turnout. Lots of chunks and very aggressive. I done a test run between application with a schultz gun and by rolling it with roller by hand. I like the roller application better. I will post pics tom.
