5-Ton Cargo Cover Installation
ElKapetan
Lancaster, OH
Does anyone have any advice for how to install an older style vinyl cargo cover on an M900 series? Or a tech manual that illustrates how? I had an awesome cardio workout this morning but couldn't even figure out which was front and which was back. I'm sure the squirrels pretty much fell out the tree laughing after I stomped away in disgust. I'm ready to swallow my pride and beg for any help at this point. All I can tell you is that mine has vinyl loops instead of D-rings and one end has nylon straps with metal alligator spring clips and the other end just has rubber bungies. Beyond that, it's just a confusing maze of straps and clips to me. Thanks loads!
juanprado
2,866
Metairie/La (N'awlins)
The newer style comes with the straps to roll it up on the sides & back already attached to the cover so you do not need straps on the bows like the older canvass style. There are also straps to go around the back bow on the inside to secure it. The front of my cover does not have straps on the front to roll up. ( no cups or loops either on the outside like the sides or back) One way to tell the difference.
Typically they are marked front or back in the inside.
Please post pics of the metal alligator clips? Not sure what those are about.
1,174
What model truck?
I'll guess you have an M939 series truck.
That may help you find and use the correct TMs.
wheelspinner
1,518
North Carolina - FINALLY !
Once you figure out front and back; lay it out. Fold it up from the sides toward the center, but all your folds should be on the outside of the cover. Once both sides meet in the center, fold it in end toward the center a couple if times. Like folding up a stuck of gum. Once you have the neatly folded cover, get up in the bed if the truck and feed it up through the center bows and unfold each if the ends once. That will hold it. Now center it front to back and appx side to side and finish unfolding out to the ends and then out and over the sides. Little adjusting and tie it up and you are done.
5tonman1971
Lima ohio
I tried to explain how to do it when you picked up the cover. I wish my truck was at the house when you were there. I guess my instructions were not clear.
the front flap closest to the cab folds around the side skirts and the side skirts in the rear gold over the rear flap. Remember I said it goes with the wind.
the side with the straps and clips is the front the side with the cords is the back
5tonman1971
Lima ohio
Here are some photos. The only way the cover is held on is be the cords and the 2 straps on the front flap.
you can see in the second picture the best, the way it supposed to be. As you can see the front flap folds over the side skirts and then the side skirts fold over the rear flap and hook to the tail gate.
M813rc
3,029
Near Austin, Texas
I'm going to borrow one of your pictures just to really clarify what's mentioned above, those triangular flaps in the proper orientation.
I've seen MANY trucks, both on SS and in military service with the tarp on backwards!
Cheers
