5 Ton Clutch Release Bearing
m139h2otruck
NH
We have finally got the converted M139 (bridge truck) water truck to a jobsite for use. Everything works great but there is a small noise from the clutch release bearing when depressed. Have tried to download manuals from the tech section on two different computers and can't seem to get anything. Is the release bearing greasable? The LO manual we have makes no mention of it and the O&M manual l(-20?) we have is the field use book not the shop manual. Other big trucks/equipment can have a greasable bearing that is connected to a hose or fitting on the outside of the bellhousing. Is the fitting behind the access cover?
Low range 2nd gear works great for watering the site and roads, but it is a verrrry long ride over the road at 35-45 mph empty with 20 cars behind you! R6602 runs fine, but seems very underpowered and under geared. Will try and post photos of the truck at work, but will have to wait for the son to do it, as I don't know how, or can't make the camera work!
1,125
FYI, I couldn't open the TM's with Mozilla (Firefox) but had no problem with MS Internet Explorer.
Jones
Sacramento, California
Looked in my TMs and it appears that the sliding collar can be lubed with a grease fitting accessable through the bellhousing inspection plate but that the clutch release bearing is a sealed bearing and not servicable. Sorry to be the bearer of bad tidings.
jasonjc
283
Gravette Ar.
You need to keep in mind that the R6602 was a power house in it's day 40 or 50 years. and that 35-45 is a lot faster than the hore and buggy could go.
just last week my throw out bearing started to squeak. took a drill bit extension and a 1/16 " bit and put a hole in the back side of the bearing. then took a needle point grease gun and gave it a bit of lube. a little silicone to plug the hole and the band aid was applied. dont know how long it will work but it bought me some time. went on a 6 day trail ride and there is still no noise. by the way this was on my XM818
