5 ton combat wheel on M54, inserts required???
Mud Hugger
Barronett,Wi
I have looked, searched, tried to find info on the 5 ton combat wheels. Or at least I believe thats what they are, have not bought them yet. I would like to put singles on my M54 log truck. I am wondering about mounting 395s on a set. Issue Im curious about is do you need inserts? Can you run tubes? Tubes with liner? I dont need to air them down to psi that the bead lock would be needed for my use. Just wondering what’s possible. Thanks guys
G744
3,660
Hidden Valley, Az
I use the pictured wheels on my M54A1.
I also run tubes/flaps on them, using an angle grinder and cutoff wheel to extend the stem hole out to the rim flange.
Nary a problem in many years of use, and they don't go flat by themselves now. I remember seeing lots of 900-series trucks at the Guard base, all leaning this way and that from leaky wheel O-rings. Nope.
Mud Hugger
Barronett,Wi
Another reason i was wondering!! Thanks for reply!
