5 ton engine swap
Knucklehead
Spencer, MA
The LDS-465-1A will fit with a few modifications. You will need the multifuel front engine mount and you will have to modify the 2 bolt holes on the front crossmember as they do not line up with the MF engine mount.These bolt holes allow the mounting bolts to pass through the crossmember, the bolts are not secured there.The radiator is MF specific, so that will need changing. The electrics and power steering hoses need a little modification.Then the linkage to the throttle pedal and handle, engine stop cable and exhaust.You can find the MF front mount at most bigger dealers like Memphis equipment. It is pretty easy to do the swap. I have done it, PM me if you have any questions.
