5 ton front axle gearing
drjconley
merced, ca
I was reading another thread and it was stated that the 5 ton trucks have an "overgeared" front end. Is the gearing on a 5 ton different from the front to the back, or is it the same? I always assumed it was the same.
Thanks, I was just interested.
Jim
1,807
Axles are geared the same. The transfer case has the front output geared a little off for the sprag.
M543A2
11
Warsaw, Indiana
The transfer is geared such that the rear wheels have to slip a certain percentage before the automatic, sprag engaged front axle drive kicks in. As Recovery 4x4 said, the axle gearings are all the same.
Regards Marti
KsM715
142
St George Ks
I remember reading in a thread somewhere that you shouldnt let the truck roll backwards from a stop (like stopped at a stop sign on a hill) with a sprag gear box. Anyone know what thats about?
BEASTMASTER
142
Burgaw, N.C.
oh yeh. you will hear the loudest and scariest noise. and feel it in the seat of you're pants....you will get out and look under the truck for the pieces.
