5 ton front winch oil?
03silverado
Millersville, MD
I'm doing some p.m. And would like to check the oil levels in my front winch I've looked over the T.M.'s but I can't figure out where to check add and what weight fluid to use if I need to add some
timntrucks
146
Ponchatoula LA
i use the 90 wt gl-1 that i use in the gear boxes. i am thinking there are 2 plugs to check each side of the winch. but i might be mistaken. i would have to see my winch to make sure:jumpin:
timntrucks
146
Ponchatoula LA
not much. as long as its gl listed. the one 5 has a slightly more concentration of cleaners i was told. i dont run any syntetic oil just the reg one that is still high as the roof; last month a 5 gal was almost 80 bucks
Marlboro
Mullica Hill/NJ
I put straight Lucas in my deuce winch, Its had no ill effects and gets used almost weekly... It has slowed my leaky seals but not stopped them.
dburt
9
NE Oregon & SW Idaho
I used 'corn head grease' (which is used on some types of farm equipment) in my deuce winch and it worked great. Corn head grease is thicker then 90 wt, but is more 'liquid' then regular grease. The idea behind it is that it won't flow out around worn seals, but is more liquid and sticks to the gears like oil. I used a 50/50 mix of corn head grease and 90wt and it worked well.2cents
73m819
329
gainesville, ga.
Quite a number of guys use 100% corn head, pump it in the bottom till it comes out the top
deuceman51
10
Scotland South Dakota
I've been using Lucus Hub Oil in all our steering gear boxes and winches and for the trucks we build for customers. I really love the stuff and have had great results with it. Seems to condition the seals and slow leaks also.
m16ty
227
Dickson,TN
Just about any gear oil will work.
I also run 100% corn head grease in mine. It's not full to the top but I put more in than if it had gear oil in it.
