5 ton grill dimensions
powersmoke18
nj
can anyone please give me the length and height of locations 1 and 2 on the 5 ton grill?? i'm stuck in tx and my 5 ton is to far away!! lol thanks guys just working on some lights to put in those spots
M813rc
3,020
Near Austin, Texas
If someone doesn't get the info before then, I'll measure it for you Tuesday (my 813 is out at the farm).
Cheers
M813rc
3,020
Near Austin, Texas
Took me a tad longer than expected, but here are your measurements.
All are inside measurements, as in usable space inside of one bar to the inside of the other.
Note- the dimensions on the bars under the headlights are actual length. Since they angle back, if you look at it head on, the uprights either side of the headlights are 9" apart.
The measurements on the three small gaps at the bottom under the headlight are usable width, as in the gap left that isn't blocked by the upright portions.
(Does all that make sense? If not, holler).
Cheers
