5 ton maintenance
derby
S.E. MI.
where can you get oil and fuel filters for M812? also where is the fuel pump? I spent an hour going over this truck and forgot to check a couple things!(too much bs'n) I should have it sometime next week.just want to be ready so I can get it to work.I will try to post pics then
derby
S.E. MI.
Do you know what filters I need,and where to get them? I checked the parts crossreferance and did not find them.
73m819
319
gainesville, ga.
napa truck store is where i got mine from, took a while to cross for the fuel, i dont have the number withme
Steamynachos
Calgary Alberta
Does your truck have a cummins NHC250 in it if it does the water seperator filter under the driver side fender is a Napa 3401 fuel filter. I have not figured out what the little fiters in the pump are yet. :)
