5 ton Overdrive Trans #
vtdeucedriver
Vermont
Anyone know what the number is for the overdrive trans??? Is it 6453???? I had it written down and I cant find it now.
panzerwillie
121
miami florida
I belive the ratio is .78 and drops about 500 rpm over the direct drive 5th gear trany , if you get both tranys you should be able to put one good one together if needed , not hard to take apart just big stuff to move around :roll:
ida34
32
Dexter, MI
IIRC the od trans was the one used in the mack powered five tons only. I may be wrong but I had a discussion with a guy at Thunder Over Michigan about this. I think there is also another trans that can be put in with little effort that gives a very nice OD for the highway.
vtdeucedriver
Vermont
Multifuel powered 5 tons are direct drive in 5th. But AGAIN I am sure that some nooby with a deuce will tell me that I am wrong.
Westech
CPL
6,104
207
cow farts, Wisconsin
The 5 tons have the direct drive trans with the multi fuel.. the cummins has a OD trans. Deuces come both ways with the multi fuel.. most will have the OD but there are a TON of military rebuilds that kept the gasser direct trans and slaped in the multi fuel engine.
m-35tom
221
eldersburg maryland
spicer trans:
first number = torque rating x 100
second number = internal specs, varies
third number = number of forward speeds
fourth number = 2 direct final, 3 od final
tom
