Kalashnikov
- 3
- 18
- NH
I'm going to be buying some parts from an M818 this week. I was wondering if anything from the Cummins multi interchanges with the LDT-465 multi? Such as the generator/alternator, starter, fuel/ip pump, etc.
So far I'm getting the hard top and the heater for sure. Is it possible to take the entire steering column and powersteering assembly from the 5 ton an use it on the deuce? I think I remeber reading that the frame mounting pattern is different?
I can get the entire truck for $1500. What happened was a loader smashed the front pushing the engine back, cracking the bellhousing, pushing the firewall in, killing the hood, radiator, and a fender.
The thought did cross my mind to take the 5 ton suspension and put it under the deuce. This truck also has 4 single 14.00r20s on the rear axles.
