5 ton rims
BMS07
23
Janesville,WI
Im looking at putting 15.5 R 20 singles on my 813a1. What are the best kind
of rims for it. Should i use the 5 ton combat rim or hemmet rims? What about
the backspaceing. Are the hemmet rims going to track right? Are hemmet rims
wider than the 5 ton combat rims? Thanks Brad
M1075
Oklahoma City
There are several options, but I would go with 5 ton rims from the M939 series. Backspacing should be about 11" IIRC. HEMTT rims will not track the same front and rear, unless you flip the rear hubs on your truck. The rims are the same width, but the backspacing is different.
