- 4,045
- 113
- 63
- Ponchatoula LA
i finally got the cummins started today with some hot batteries. it didnt run to good though, first i pressured the tank up via the vent lines and got the fuel to the pump. cracked a line and then after a few pump on the manual it started up. i didnt let it die and let it leak fuel some till i could make it under the hood to tighten it up. ran it for over an hour charging the batties up. it died a few time but started right back up. the fuel gauge was reading aroung 30 lbs. and the throtle response wasnt like it used to be. i finallly hit hte kill switch and nothing. i had to put it in gear and make it die. is the new electric cutoff switch bad? im at a lost, any help would be helpful.
