The MWO was not a total unit (all 39/809 series) but a user unit mwo meaning a unit using a 39/809 had a choice of installing the mwo or not. I got the mwo info from "Military Vehicle Magazine" about 2000, the reason given for this mwo was that soldiers were getting injured and trucks were getting tore up during front end lift tows due to the sprag operation (lazy recovery crew by not pulling cap or drive line as called for), the MVM article said that as a side effect of the mwo was the being able to put the sprag in NEUTRAL while on road use, the mwo was aimed at the 39 series but also pertains to the 809 series because the same sprag setup is used. The mwo called for a deuce front wheel drive air switch/light, fittings, hoses cut to fit to go from the air supply to the dash air switch then to the trans. air sprig control switches, there never was a "kit", just a parts list.
