acme66
- 8
- 0
- Plains, Montana
I run the truck the exact same way everyday and keep meticulous mileage and maintenance records. It would be a perfect test bed for ideas you might have. For instance I can tell you that switching to 90wt in the axles and transfer case will give you a .2mpg fuel economy boost. Making the air cleaner mod gives you another .2mpg when the original is about half of service life. I can say definitely that running 40-45psi in the rear and 60psi in the front will cost you about .2mpg over running 80-90psi all around. I can also precisely describe the effect switching to a real transmission fluid over motor oil has on day to day operations. Additionally I have my oil tested and can post those results with the spin on oil filter versus the original cartridge.
My hope next year is to change to a 5 inch exhaust and do the duel fuel line modifications and see if that helps. Also switch it over to wet hubs in the rear.
The truck is a 83 M925A1 so not everything will translate but what we do is so uniquely repetitive I can provide useful info.
Let me know some ideas.
Ken
Ken
