Not at all; not with the 395's on FMTV wheels.... any rub issues?
No runflats or beadlock inserts on the standard 1100 tires on an 809 series. You can obtain runflats and inserts for the combat wheels but not required.Thanks guys.
Will I need to remove the runflat lines or how do they work on the m809 series?
I think he means the CTIS lines on the wheels. Those should just be removed and a valvestem used.No runflats or beadlock inserts on the standard 1100 tires on an 809 series. You can obtain runflats and inserts for the combat wheels but not required.
A lot of guys are switching to 395’s. Lots of tires available.365/85r20 is another option....about 2" shorter than the 395 n I see some reasonable prices on XZL Michelins.
You can regroove them and add more life to them. Around $150 for the tool and bladesMy 14.00R20's are getting a little thin in the tread....I will probably go down to the 395's. I am always towing heavy so the 16's prob won't work for me. I am dreading going smaller.....the 16's just look super bada$$.
