5 ton winch interchangeable
ross165123
hickory nc
This may be a really stupid question that has already been answered and if it has please tell me where.
Can one mount a m939 series hydraulic winch and a m809 series truck easily? They seem to be much easier to find. Any input would be nice,i just cant seem to find any information on it.
m16ty
211
Dickson,TN
I don't see why it wouldn't work, you're just going to have to install a hyd pump and valving to run it.
A hyd winch should be a nice upgrade compared to a PTO winch.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
From what I have seen, they are the same. I have a hyd motor from a 939 series truck to convert my winch on the M62.
Artisan
227
CDA Idaho
No such thing as a "900 Series"
There is an M939 Series. Period.
It is what it is, adopting slang can be VERY dangerous.
Where is Doghead when we need him!
73m819
319
gainesville, ga.
The winches ARE the same BUT the 939 hyd. drive WILL NOT clear a 39 series or 809 series radiator, the 939 series radiator has a relief for the hyd. drive and sits higher. The way around this is to shaft drive the winch, with the hyd. drive driving the shaft.
THIS is a lot of work to hyd. drive a 39/809 series winch just to turn it into a lower class winch that will do less then the original winch drive.
Gunzy
65
Roy, Utah
I have never seen a releif in the M939 series radiator. But there is a releif in the forward crossmember on the M939series truck.
m16ty
211
Dickson,TN
Ron, I wondered about that. I know that is the case on deuce but didn't know about the 5-tons.
73m819
319
gainesville, ga.
Thank you,
I remember the relief, just forgot where, though the 939 radiator does sit higher which clears the top of the hyd. drive.
