5 ton winch part needed
sermis
17
Temple, TX
I scored a 5 ton winch several months back. Was thinking of adding it to the rear of my deuce but it sure is big. I am in need of the bearing retainer plate that goes on the PTO shaft and the drum lock. Anyone have access to parts that might be able to help?
acetomatoco
TNJ Murray and Sam Winer Motors have had big piles of scrap winches in the past.. maybe some still there....
sermis
17
Temple, TX
Yes I found the part needed. Anybody need a winch.
I got a winch for a M35 that I think I am going to use insted of the 5 ton.
Sephirothq
26
Trevorton / PA
I need the brake parts from a five ton winch. The parts on the opposite side of the drive shaft input side. I need the small aluminum housing the brake band, the bolt, the spring and the cover. I also need the round cross rod on the bottom.
