- 4,271
- 1,739
- 113
- Edmond, Oklahoma
I was recently given a 24V aircraft battery charger.
It’s an older one but in excellent condition.
A switch can change it from just powering the aircraft to 50A battery charging mode.
It is an automatic charging system and not just a straight charger.
Is 50A too much for a stock NATO system and Hawker battery’s?
I know the plug itself is rated much higher.
The plan is to remove the aircraft power plug and install a nato plug.
That way, if I ever need to charge the battery’s, I can simply plug the nato plug in and charge them.
Overkill?
If it’s too much charger then I won’t use it.
I don’t want to damage my Hawker battery’s.
Overkill?
