- 2,293
- 862
- 113
- Fargo ND
OK I know the title sounds like something really bad but I am not painting my M37 yellow I promise! Here is my question, I have a 1952 M37 and as I have been working on the truck getting it roadworthy I keep noticing like hi Visibility yellow looking paint or primer showing through in spots on the frame, inside the fenders and even on the soft top supports, these are small little spots etc. but my question is where did it come from? At first I thought that it might have been a county/municipality truck and they painted it this color? If that had been the case it would just be on the outside of the truck, this is every where, I pulled the screws out of the window access port in the door and where the screws go through the panel to hold it to the door there is yellow in the screw holes. The truck has OD green paint on it and in sanding I can see the normal brown primer under that but then I see yellow, could this be something that was used to etch the steel before it was primed?
Any ideas??
Karl
Any ideas??
Karl
