52 m38a1 wiring harness
nickd
36
Newport, Delaware
I need a new wiring harness. What are my options? Can I use a mutt wiring harness or do I need to find one with Douglas connectors? All of the lights will need to be changed and the gauges could be changed as well. Am I missing anything?
Maverick1701
181
Lubbock, TX
I used DeBella Jeeps for my replacement harness. New harnesses run around $800-ish from all the manufacturers (or at least from all the manufacturers I could find)
wilfreeman
Richburg, SC
Pretty sure all of them come from Vintage Wiring, but can't prove it. Every once in awhile you'll find one on ebay but you run into the same problem of aged wire. You can convert an M35 front harness to the M38 and a1, but it is a lot of work. This option can be a lot cheaper if you find a cheap NOS harness to start with. You can prob convert an M151 harness also.
if yours is brittle, you might as well bite the bullet and do something before she burns to the ground! I am in the same situation myself - mine is very brittle and not all systems work as they should. A friend found an M35 (early, no turn signals built in) harness on ebay VERY cheap for me, but I haven't started the conversion yet. Wes has info and diagrams on willysmjeeps showing how to do it.
