Hwhomes
- 0
- 0
- Moses Lake WA
Has anyone tried the Michelin 1600 X r20 tires on their LMTV? They are 53" tall and would seem to be a way to lower RPMs or increase speed.
Where did you get your gear sets?My regear cost me about $900 all in. Including gear oil of the high quality type with Lucas additive. Where can one get 4 tires for that?
Sure thing. You have my cell.Where did you get the parts/work done? Are you happy with the conversion? Perhaps I could drive over and take a test ride?
The work was done by me and a friend in about 7 hours. Best mod so far. It's like adding another gear! More power was and is still needed...Where did you get the parts/work done? Are you happy with the conversion? Perhaps I could drive over and take a test ride?
how does either of these engine upgrades change MPG? Looks like I'll have the fast Axles but still would like more MPG.A turbo and rack adjustment will get you up to the 5 ton 285 hp.. If you raid the marine parts bin for the 3116 an injector /turbo change will yield 425 hp.. But alot of marine engines like to drop exhaust valves so I'd stress an exhaust valve change.
It takes fuel to make power..how does either of these engine upgrades change MPG? Looks like I'll have the fast Axles but still would like more MPG.
What I figgured. worse MPG.... when your pushing it... but available power to push too that was not there before.It takes fuel to make power..
